Root diag mode?
i googled around yesterday looking for a way to get the n861 into diag mode and nothing popped up...does anyone here know how to do it?
advTHANKSance,
fA
well, the mode closest to what youre looking for would be the result of holding up and down volume while holding power to turn the phone on if im not mistaken, it will basically seem to freeze on andy, dont know if it will help you though never tried accessing it using third party software
usb tether might also get the desired results depending on how its set up
and there is a slight chance the options tucked away somewhere in one of the normal spots when you dial the right code on the stock rom though i dont think it is
you could always try though, ##diag# or ##debug# if i remember correctly
