dialer app help
You can put direct dial shortcuts on your home screen. Long-press on your home screen and select shortcuts>direct dial. Then just choose the number from your contacts.
I did what you said but there is no dialer in that app that I can choose from. Where would I find the dialer app? Just started using this new phone and don't know all
the ins and outs unfortunetly.
If you want to use direct dial shortcuts, the number must be setup in your contacts list. If you simply want a shortcut to the dialer on your homescreen, open your app drawer and long-press the icon that says "phone". Drop it on your homescreen wherever you want it.
Questions are best asked in the section for your specific phone model since each model has unique features that may or may not be shared with other models.
