Root Dialers for Micromax A75
well going to try out now.!!
but first let me make a nandroid backup.. just in case.. ;)
What modification does this dailer has can u please let us know about it.
Brother, It has completely transparent dialer .I had seen similar dialer in a video
of a phone with CM7 .I tried to copy that look.
The update 3 in my thread contains --
contacts.apk
phone.apk
mms.apk
These apks will change your dialer ,in-call background ,new icons in messages
and a few more icons in blue color.
Thanks.
There is a problem with the files what u have provided as if when i flashed them i dint find Contacts, Phone, Messaging on my phone check it as if i am using Blue Terror V1.6
Download it again bro and then try once more coz the zip file is perfectly ok as i got it work at the very first go.. The dialer is cool amd matches the rom.. Thanks firoz for the awesome update..
Coulld u let me know which fiels u downloaded as if i just downloaded the Dailer2 update and the keyboard update so tell me which files u downloaded.
I am using this with blueterror 1.6 and its working like charm, now I dont have use stupid apps like exdialer and ics keyboard for the good look.
SUPER AWESOME!!
how did you guys downloaded it? is it via pc or mobile? if its mobile which browser?
i've downloaded it via mobile through opera and it works fine for me..
c'mon guyes why is it not working for you.!!
it is perfectly alright.!!
the new dialer look is awesome you know.!!
the new key board matches the BT theme.!
i was also on bt v1.6 but successfully flashed the very first time.!!
yaa not working for me too
Brothers,
I am sorry for those whose phones could not take the updates properly.
I can not do anything for you as my updates are working on some phones.
You may try wiping data and partition before flashing it.
Flash the updates 2 or 3 times repeatedly.then reboot.
I hope this may work.
Brothers ,I have placed a request to aayush to provide you all an OTA update for the dialer2. I hope he shall provide you soon.
Brothers,
Problem sorted out ;)
Unpacking ur apps and copying res folder to the original unpacked app and then packing original ones again and then flashing them works perfectly :)
That actually means there is some problem in ur comipiling of apps :o
@firoz the dailer background is awesome. Can u please add this as background for contacts, call logs, favourites and settings :o. It will look fantastic:). Btw thanks to u for great modifications.
And pls can u add cyan glow when any alphabat in keyboard is touched?
I had tried these all bro but failed.
To do this more than sufficient knowledge of xml is required.
@All,
Can somebody please post screenshots for people to see the new dialer?
I do not have access to my phone otherwise I will do it right away..
It will be easy for people to see the screenshots and then decide if they want to flash it or not.
@Firoz,
Bro, whenever you get the time please post the screenies on the very first post.
Thank you all.
