dictate a message and then it makes a call
  • Start date Start date
A
Android Question
Guest
I punch in correct screens to dictate a message and it makes a call instead. How does this happen? How can I fix it ? Galaxy S4
When you dictate a message do you put your phone to your ear? If so, you probably have the smart dialing (or at least it is called something like that) turned on. That means that when you are in a text and you put your phone to your ear the sensor notices it and it makes a call. You can disable that in the settings.
