Dictation Question
iwchris
Hi Guys
I do tend to use dictation a lot for e-mails, but I do find Android very frustrating when in the middle of a line the letter i does not auto capitalise, is this something that I can adjust in settings or is it just not as good as ipad dictation?
Thanks
Chris
It's not Android, it's the particular STT app you're using. Mine capitalizes the individual word "I" whether I want it to or not. I don't think Dragon Naturally Speaking is available for Android yet (the Go version is) so you'll have to try different engines until you find one that works best for you.
Thanks very much for your reply, I didn't not know that it worked like that I will give a few more apps a try.
Chris:thumbup:
