Accessories difference between batteries
Just noticed that the two batteries I have for my incredible have different info on the back.
Battery 1:
Model BTR6300B 1300mah 4.81Whr Li-ion Battery
P/N: 35H00134-02M
Battery 2:
Model BTR6300B 1300mah 4.81Whr Li-ion Polymer Battery
P/N: 35H00134-11M
Simply put, they are exactly the same 1300mah battery for the incredible, but one says polymer and with a different part number. Can anyone shed some light, and if so which one is the better of the two? Thanks.
I wouldn't think there would be a noticeable difference between the two, nor that anyone has done any comparative testing to determine any differences being that they're both OEM 1300 batteries. I'd say the difference is nil.
Battery 1:
P/N: 35H00134-02M
Battery 2:
P/N: 35H00134-11M
I have 2. 02M and 03M. They both say polymer. The 02M was horrible. Verizon sent me the 03M which is slightly better.
I know it.clears nothing up but its more info.
