jmhemiram Member May 5, 2011 #1 My internal has a lot of space left. The other 2 are getting low. What does each do? What saves to each? Thanks
S sdrawkcab25 Extreme Android User May 5, 2011 #2 jmhemiram said: My internal has a lot of space left. The other 2 are getting low. What does each do? What saves to each? Thanks Click to expand... the internal is space used for storing anything but apps, the other is just for apps and your sd card is for whatever you want. http://androidforums.com/htc-incredible/243403-storage.html?
