different calendars on different applications
uur641
Hi,
I have on my phone 2 accounts:
1. Exchange (work related)
2. Gmail (personal)
I want to have different calendars for the two accounts on different applications.
I tried installing several calendar applications, but when I configure one application to show only Exchange it affect the other application as well.
I cannot get to see on one applications my exchange meetings and on the other application my google meetings.
Thanks,
Yuval
Hi
You dont say which phone or which calendar apps you have tried....
If you try/use Business Calendar by appengix on Playstore you can easily toggle the calendars on and off in the same view ie only one app needed. Should work well with only 2 calendars.
I dont know why settings would carry across two apps as you describe
Roger
I am using Samsung Galaxy 3.
I installed now the Business Calendar by appengix and got the same result.
whatever calendar to show that I configured in this calendar affected my Gmail calendar.
Hi again
In business calendar turn off/on visibility using the tabs at the bottom of the screen. The calendar app still syncs the calendars but does not display them. It should solve your issue I think.
Roger
