Different wifi question
Jeffruby
I am not having problems with wifi dropping, but instead get this annoying notification that "wifi disconnected" when I leave a wifi zone.
Just don't want the notification. Can't figure out how to disable this alert. B
After looking at it I see no way to turn off the notification.
You may try deleting that WiFi connection and reconnecting to it.
Not sure if that will help or not.
Good luck.
