D
Deleted User
Guest
Hi,
Ok, I'll describe my situation briefly.
I have main_actvity.xml file which looks like this(just followed Android Devs guide):
As you can see there are two fragments that are placed with 1/3 to 2/3 ratio one above the other.
The problem is when I work separately on, say: fragmentOne.xml file (via Design bar in Android Studio. )
It shows me that this layout actually fills up all the screen space.
So as far as can understand the final output layout will be dictated by main_activity.xml and all the great stuff that I would add to fragmentOne.xml will be resized in order to fit onto screen.
My question is about fragmentOne.xml (and fragmentTwo.xml too ^_^) is there some good way to define its dimensions so they initially suit those defined in main_activity.xml?
I mean in such case I'll work within a dimensions that will be actually presented to user, and will place all the elements(inside fragmentOne.xml file) in a proper way.
Without having a headache of rearranging those elements afterwards due to re-sizing of main_activity.xml.
An example of my fragmentOne.xml file:
Thanks a lot for help. (hope my question was clear ^_^, and yes I'm an Android newbie)
Java:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
android:paddingBottom="@dimen/activity_vertical_margin"
android:paddingLeft="@dimen/activity_horizontal_margin"
android:paddingRight="@dimen/activity_horizontal_margin"
android:paddingTop="@dimen/activity_vertical_margin"
tools:context="com.example.ivan.fragmentsgameplay.MainActivity">
<TextView
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:text="Hello World!" />
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_height="match_parent">
<fragment android:name="com.example.ivan.fragmentsgameplay.FragmentOne"
android:id="@+id/list"
android:layout_weight="1"
android:layout_height="0dp" />
<fragment android:name="com.example.ivan.fragmentsgameplay.FragmentTwo"
android:id="@+id/viewer"
android:layout_weight="2"
</LinearLayout>
</RelativeLayout>
Java:
<FrameLayout xmlns:android="http://schemas.android.com/apk/res/android"
tools:context="com.example.ivan.fragmentsgameplay.FragmentOne"
android:background="#323b8a">
<!-- TODO: Update blank fragment layout -->
<Button
android:id="@+id/frag_one_button"
android:layout_gravity="center_horizontal|top"
android:textAllCaps="true"
android:text="Go To Fragment Two" />
</FrameLayout>
