Ding Dong sound driving me insane!
A bug or something turns up my alarm volume to full and a door bell notifications rings 5 times a day. I cleared cache in recovery mode, turned off NFC, deleted all apps since it started, turned off all congestion alerts on Google maps, I don't have Yahoo, turned off all notifications and the reminders (pics attached). I've run out of ideas.
People are laughing at my new phone and I'm getting looks during meetings, credit to the speaker as it literally makes people jump it's so loud. The usual Apple guys are telling me 'I told you so' again.
Help me Obi wan Konobi you're my only hope.
You might try going into Settings/Notifications/ and then scroll to the bottom of the page and tick See all. You will see a list of apps that are set for notifications and entering on each you can manage each app's notification settings. I'm guessing you will find an app that has notifications enabled with that annoying doorbell sound checked. I hope this resolves the problem.
Thanks guys, I went through the apps one by one and brutally turned most off, I have a suspicion it may be chrome. I'll let you know in 24 hours if it has worked.
This just gets stranger by the day. I've turned off all notifications for all apps and still it's the same. Also I've checked all the sounds for app notifications and the ding ding/doorbell sound isn't there. Where is it coming from???
Also will this happen several seconds after you've walked into a room? Blue tooth connecting?
