KI Mobiwares
Simple utility to organize your Direct Dial/Direct Message/Direct Email Shortcuts
FEATURES
1. Create Direct Dial/Direct Message/Direct Email shortcuts on your home screen
2. Organize or Group related shortcuts into folders
3. Create Multiple group folders
4. Assign different icons to each folder for easy recognition
5. Easy creation, deletion and modification
6. Easy Navigation
7. Beautiful Theme.
BENEFITS
1. No battery consuption since it is a shortcut rather than a widget which continuosly runs in the background
2. Move the App to SDcard unlike widgets
3. One action creates shortcut on all launchers/home apps installed. So no need to individually create on each launcher/home app and you can change launcher/home app easily without worrying about loosing the shortcuts
MORE FEATURES TO COME
1. Search through contacts
2. More themes with round and square themed contacts
3. Different Icons Sets
4. Backup and Restore facilty for created folder
This is in beta version. So please report any bugs via email (directcut@klausit.com) instead of providing bad comments
If you want to add any new feature, you can send your suggestions to: directcut@klausit.com
PLEASE NOTE : THIS APP CANNOT BE USED TO SEND GROUP MESSAGES/EMAIL
Website Link : Klaus IT - Mobiwares
Google Play : Download
FEATURES
6. Easy Navigation
7. Beautiful Theme.
BENEFITS
