Direct Dial Shortcut Enabling/Disabling Google Voice
thornomad
Hi there - am new to Android and to these forums. Have a Galaxy Nexus. Love it.
I use (and have used for some time) Google Voice. I make 99% of my calls through GV and that's the only number I give out.
However, there are three or four family members I call directly using my real cell number (Mobile-to-Mobile minutes reasons - and these folks never text me so it's fine).
Is there a way I can program my direct dial widgets for these three people to *not* use Google Voice? I have tried the GV toggle widget as well as being prompted for each call (both are a bit of a hassle and have led to some mis-dials) ... but what I want is to *always* use Google Voice except for the three direct dial widgets I have setup.
If there isn't an app for that, can it be done programmatically doing a shortcut-creating app?
Thanks in advance.
Damon
Daemon, take a look at the app Voice Choice. That lets you set up a list of numbers which you don't dial via Google Voice.
Hope this helps,
Ambarish
