A
Android Question
Guest
Hi....!! I hav recently brought the hp 7 voicetab.The problem is,its internal memory is quite low and after downloading few necessary apps and asphalt 8,i hardly have any space left to install other apps.I hav rooted my phone and used directory bind to move all app files to sd card.It works fine but isn't permanent.I hav to manually bind it every time I clear my ram(using CM master) or simply reboot my phone.I hav checked in the box in preferences to bind after reboot but it still isn't working.Please tell me a permanent solution to my solution.
