Root Dirty Unicorns 3.6 Custom Font Issue
droiddekka
trying to install my (DROID) font via the font installer app from the play store, it installs and reboots like normal but the font does not apply.
i noticed the font for a brief moment in the browser app but after playing with the hybrid settings it has reverted back to the stock font :confused:
i'm running hybrid in stock UI mode 240dpi 360p and am scratching my head really hard on this one.
i know it can be done...and i've tried to change fonts with rom toolbox also same results.
holler at your boy
Have you tried any different fonts just to be sure it's not a issue with that particular one. I'll installed different fonts w/o issue with the rom toolbox and that method has worked fine for me.
I also want to make sure you using the Evo 4g because you mentioned DU 3.6 and the latest version for the Evo is 4.2.
http://android.aokforums.com/1-vt281.html?sid=41b36697d765a7eabe85dc2d3080aa99
Yep. I saw two different fonts change from within the browser app, but did not take effect anywhere else. Browser app properties are identical to the global properties within hybrid settings
