Disable certain Settings
jonikwg
Hi androidforums,
i have a question regarding the Settings of Android 2.2 device. We are corporate and want to disable the use of applications, this we have done successfully with the help of an app. however i was wondering if we can disable system settings, so that the user cannot change settings. the only thing they should be able to change is the Ringtone and Language of the device, however not change anything else. Because they keep messing with the seetings and then complain that stuff doesnt work anymore liek its supposed to. is this possible in any way?
regards,
joni
