Disable or Lock Task Manager !!
ila420
Hello,
I have a problem, my kids usually play games on the mobile and they access task manager to kill the games, i have Go launcher on my the Mini and it shows in the task manager as running application which also get killed by my kids using task manager.
Go launcher has an option to lock the screen which doesnt let my kids move or uninstall any application but when it is been killed using task manager they delete applications and i have to run a restore via app monster to get back the stuff.
Is there anyway to lock or disable the task manager or change the way task manager appears by holding down home key so my kids wont be able to access it, Go Launcher has this good option to lock the screen but i cant find any option to lock or disable the task manager, any help on this would be grateful.
I am on froyo no idea about rooting so waiting the official 2.3 firmware to release in my region which hasnt yet.
Thanks.
Try app locker pro from the market to lock apps. Also lock settings and any apps that u dont want your children to access.
