When I long press on a widget, I get the usual selection of remove or resize. But now with my new G2 I get disable padding as an option. Anyone know what it is?
When you disable padding you can then size the widget from edge to edge on the screen with no gaps. Padding is a little invisible area around the widget so their is a little space between other widgets or the edge of the screen. If you disable it you won't have it.
Hope I helped.
