JScottTuck
I am having some issues with getting Tasker and Secure Settings to disable my pattern lock. It's weird. Sometimes it works, sometimes it doesn't. My Galaxy Nexus with Cyanogenmod is rooted, Tasker and Secure Settings both have root permissions, and I even set both as Administrator under the security settings. I've noticed if I reboot the phone, or uninstall and reinstall secure settings, it will work fine for a day or so, but then stops. I've also noticed that the "toast" that pops up on the screen to let you know Secure Settings has performed a task doesn't come up.
I checked the Tasker log file, and it shows "Status: OK" 9.2.2 Anon.Secure Settings, so it appears to be executing the task properly. It appears as if Secure Settings just isn't functioning.
Basically, what should happen is that when I disconnect from my car dock, Tasker should re-enable the Pattern Lock.
Profile looks like this:
Context:
Docked Car
Enter Task
1. Variable Set
Name %Car To on
2. Secure Settings
Configuration - Keyguard Disabled/BG
3. Secure Settings
Configuration - Pattern Lock Disabled
Exit Task
1. Variable Set
Name %Car To off
2. Car Mode
Set off
3. Secure Settings
Configuration - Pattern Lock Enabled
Restore Settings and Enforce Task Order are both unchecked. Any suggestions would be greatly appreciated.
Context:
Docked Car
Enter Task
1. Variable Set
Name %Car To on
2. Secure Settings
3. Secure Settings
Exit Task
1. Variable Set
Name %Car To off
2. Car Mode
Set off
3. Secure Settings
