Disable stock volume
Tijs67
I am using Fine volume for adjusting the volume on my device.
The stock volume still remains active and makes it hard to easily use fine volume.
Is there a way to disable the stock volume so that, with adjusting the volume with the hard button, only Fine Volume is used?
