Help disable timescape
if you remove timescape after rooting will it screw up anything? i know timescape was sonys big thing. im gonna root mine soon and dont wanna yank it and find out it affects something else.
I've frozen both Timescape and Mediascape using Titanium Backup and have experienced no problems at all.
I would recommend to buy Titanium as it gives you an option to freeze applications rather than just remove. This way you can experiment with what you want or don't want without the hassle of reflashing if you remove an essential app or service
Some might want to leave MediaScape alone as it is needed to manage contact photos. Personally I couldn't care less.
i dont mind media scape i use it all the time, i just wish it was a little faster. timescape i deleted last night :D
