Disabling Cam widget on KK lock screen
AM_SOS
Hi all,
I recently enabled the widgets (on the security settings in KK).
After checking them out I decided against enabling the option. While all the widgets were switched off after I disabled widgets from the security settings, strangely the camera shortcut continues to be functipnal on the lock screen.
Is there some way to disable it or is it always on by default on the lock screen? I seem to recall that the widget wasn't present earlier on the lock screen and only came up after I enabled the widgets from the security settings.
Thanks!
