I have a Motorola Defy Mini, which comes bundled with various software including an app "Mediaser", which seems to be for sharing media via DLNA.
However, the phone's internal memory is very limited (only about 160mb or so), so I have to be careful with how many apps I load that can't be moved to the SD card.
I've recently loaded a bunch of music onto my SD card, which works great for playing on the go, except that it's causing the Mediaser app's data usage to increase until my internal memory is full! I don't use the app at all, don't have any of its features enabled or anything, but it's still consuming data. It's obviously got some kind of content trigger(s), as any time I clear its data it just starts up again the next time I add a song or restart my phone (by that I mean forget to charge it
Anyway, I really need a way to disable it completely, as I have no intention of ever using it; kind of one of the biggest issues with this phone really, even though it has pathetic internal memory, Motorola decided to lumber with a ton of apps that only use internal memory for storage
).Anyway, I really need a way to disable it completely, as I have no intention of ever using it; kind of one of the biggest issues with this phone really, even though it has pathetic internal memory, Motorola decided to lumber with a ton of apps that only use internal memory for storage
), so it may not even be possible.
