Help Disabling the vibration for incoming call & disconnected call
Where are you setting it off? Here's where you need to do it:
Settings/Phone/Call Alert/Outgoing Call Vibration
Settings/Phone/Call Alert/Call Status Tones
Bingo! there is your problem.
Try to uninstall both apps and see if that solves the issue. I recalled Viber messing up vibration settings on my phone too, I had removed it long time back.
i may have found the fix
- select phone icon on desktop
- select three dots in upper right corner
- select settings
- select call settings
- uncheck vibration reminder
