DeWet
I have a Note 2 7105 with a working cracked screen and a Note 3 9005 with a non working cracked screen. The Note 3 starts up and play the startup sound but then ends with the little blue light pulsing and I can't pick it up on the pic through the USB cable.
Before I buy a lcd and digitizer assembly I want to make sure the phone still works.
Will I be able to use the display from the Note 2 on the Note 3 to verify this?
Are the connectors the same?
Even if it's just the lcd without the digitizer that will do
