Help Display problem
Put it in a ziplock baggie full of rice for several days, perferably with the back off, and hope it is not permanently damaged.
How did you determine that it is a moisture spot?
If it got wet, and you turned it on, it is likely toast.
Yep, glc gives the best advice. The key is to wait. I had moisture get behind a laptop screen and it took weeks to get rid of it, but it finally came around. However, a laptop screen is not a touch screen (or at least not on that model).
When i press the screen this moisture spot moves and also spread. If i put my mobile in sunlight it disappear but after some time it appears again.This problem is appearing from last 10 months.....
A wet moisture spot on the centre of screen......what is solution
I think you have gotten some good answers. I didn't read them all but once I had this on a device and I set it in the Sun. Might have taken several times. I don't think I set it where it would get too hot. Good Luck!
