Hey all
okay so this is part battery issue as well, so the cell standby is using up 43% and i know about the problem etc
but my other issue is my display is using 48% together its killing my battery
my display setting are as follows;
brightness at lowest possible
screen timeout - 15sec
touch key light - 1.5sec
screen mode - standard
auto adjust screen power - on
normal wallpaper too
i dunno what else i can change to lower the display, after 3 hours and 37minutes my battery is at 87%
any help or suggestions on what i can do to lower the display usage would be helpful
