Help Display quality
Empire
What do you think about display(contrast,quality,etc)? it's worse than display of galaxy ace ? or it's better, i see that sony live walkman have 180 ppi and ace have 165 ppi.
I don't know about ace, but it is good enough for regular use. Twitter, facebook, msn, some basic games - quality is good enough.
The display is of good quality but the contrast is a little low but it is only slight and it doesn't effect my daily use :)
Display is really good even its resolution is 480*320. But it would be better if this phone had 800*480
its display is way better than that of galaxy ace. I took both phones in each hands when I was making a decision and this one won with much ease. its specs are also better than ace, apart from the screen size. but considering the price difference between the two, this one is pretty awesome!
Definitely better display than Galaxy Ace. In fact it has really good display for its class!
P.S. Andima, if you root your phone you can install BRAVIA Engine.
I'd say display is better that it's competitors. my last phone was htc desire s which had 252 ppi. but my non-expert eyes see no huge difference between them.
Hi,
Since a couple of days I've noticed that my screen flickers sometimes.
Mostly when I'm moving my hand while holding the phone...
Is it possible that the light sensor auto adjusts my screen brightness ?
If so, how can I turn it off ?
Thanks in advance,
Niels
(PS : sorry for posting here but I'm new so I can't start a new thread yet..)
NelisC, I've noticed that too. I was wondering what is going on with the phone screen? Is it normal?
I'm sure now that it is not a problem with the screen, it's the light sensor..
I was standing near a window and put my finger several times on the sensor and it clearly adjusted the screen brightness automatically.
Glad that it's not a problem with the screen, now we've only have to find a solution.:p
EDIT :
Oh, forgot to mention this :
I found a widget that you can add to your homescreen "On/Off backgroundlight". (not sure of the name though because my language is set to Dutch)
It's the first widget in the widgets list..
If you turn off the backgroundlight with this widget the screenbrightness is not adjusted automatically anymore ;)
Downside is, the screenbrightness is then set as low as possible. But that's fine for the evening :)
Grts,
Niels
NelisC. yup I use that widget too its called "on/off backlight" its ideal when ur using the phone in darkness, I use the widget when battery is low and when im using it while on bed
lww have a poor display we know that but my question is if i install bravia engine is it improve it s quality? please some one answer my question?
if you had read the above posts, you'd realize that its display is wayyy better than its competitors.
