Help Display Screen Timeout Setting switching...
drexappeal
Extreme Android User
Not sure if anyone has experienced this yet, but I typically leave my screen timeout setting to 5 minutes.
But, the Note 3 (and actually my Note 8 wifi, which just got updated to 4.2.2) seem to not like that setting and then it switches the screen timeout to parenthesis, like this:
It's pretty annoying because that setting turns the phone off as soon as I'm not touching the screen. I'm figuring this might be one of the new Samsung software features that's causing it, but I wanted to see if anybody had experienced it or knew the setting, so that it won't mess with the screen timeout setting.
I should also mention that, the only reason I suspect it's a Samsung software issue is because my Note 8 (wifi only) tablet just got updated to 4.2.2 and this issue only started happening, after the software update (which included some Touchwiz enhancements).
Thanks in advance.
