Display Using 97% battery after upgrade to froyo 2.2
enter21st
Samsung Galaxy 3 Apollo i5801
After
the latest updates to android 2.2 froyo, my display will be
sitting at 97% usage, when it's just
sitting in my pocket. Totally battery
drain in about 7 hours with little to no
usage at all.
plz somebody helpme.
check for apps running in background, turn off data connection when not needed, make sure your not syncing emails very 30 mins etc!
no apps runnig in background, no data connection and sync running still display used the full battery.
Plz Help Me My cell's battery life is very bad after upgrade to 2.2 froyo
Some Useful Information about my Mobile
SAMSUNG GALAXY APOLLO I5801
FIRMWARE
2.2 FROYO
BASEBAND VERSION
I5801DDJP2
KERNEL VERSION
2.6.32.9
ROO@SE-S605 #2
BUILD NUMBER
FROYO.DDJP2
BUILD INFO
2011.04
PDA
I5801DDJP2
PHONE
I5801DDJP2
CSC
I5801ODDJP2
THX.
is wifi, bluetooth, 3G on? is screen set to max brightness?
i turn off all unused connections till needed
set screen to minimum brightness
installed app killer to turn off all apps every 30 mins
mine lasts for 4 days on average
marcel
marcel
i turn off all connections.
but still display using all battery
my cell battery lasts for a day only.
