suhel28
Change your theme yourself.
add animations and battery percentage to any theme you want.
download this attachment Framework.7z and extract the files.
open the framework-res.apk file with your zip manager (7zip, winrar etc)
and
replace the files as placed in the zip file to it
only part to take care is the resources.asrc file you don't have to replace it directly
do this steps for replacing resources.asrc
thats it you're ready to go
and
- right click the resources.asrc
- select add to archive
- archive format zip
- compression method Store
- select the path of your framework-res.apk
