Help DNA wont charge because USB Host Mode is on
FRACer
I cant find a way to fix it/turn it off. Any ideas? Am I stuck getting a new phone? I have seen that this issue exists but it appears more common on the One. Cant find a troubleshoot. HELP!
If it was a setting, a factory reset would cure it, but suspect that's not why.
Turn it off completely and plug it in for charging. You should see a charging symbol on the screen. If not, you may have a hardware problem.
Same problem here. I can charge it in a regular wall outlet, but the car charger drains it more, if anything. Like others have said, recent updates seem to have made the battery drain faster so now I need to be able to recharge during the day. Found these instructions for the HTC One, but didn't fix the DNA:
1. Turn phone OFF
2. Let charge for AT LEAST 10mins even if it doesn't look like it's charging (mine DID show the new charging animation)
3. Press and hold POWER + VOL UP + VOL DOWN for AT LEAST 2mins. Anything less will not reset the charge mode.
4. After 2mins release the buttons and the phone should boot as normal.
