Do Not Disturb Feature?
2euro
Hey tasker gurus. I was wondering if you can help me out with my current task. It's not working properly. Currently its sending everyone to voicemail no matter what for my Do Not Disturb profile.
What I want
A "Do Not Disturb" feature similar to iPhone. Where if on, sends the caller to VM unless you are in my starred list.
My Tasker settings. I noticed 9 and 10 are reversed. I've fixed that.
Do Not Disturb end
Widget icon button
Totally different approach to what I did. I simply turned the volume down, then had a task triggered by a contact calling me that turned the volume up.
Wouldn't know how to start with voicemail though.
So, I've decided to go this route until I find a better option for turning on/off the "Do Not Disturb" feature.
When ON if a call comes in and they are not in my favorites list it will go straight to voicemail. Call Block basically has an EndCall task. To turn on unfortunately you have to open up tasker and click on the check. otherwise its got the red circle. For some reason I cannot create a widget icon on the desktop for an on/off method if its setup as a profile.
A variable that the new task maintains to keep track of whether the call blocker is on or off. Then use action Tasker> Profile Status to switch your profile on or off.
Here's the task I had created. Once you create this task you can then just create a widget to place on your main screen for the on/off switch. Also, you'll need to set up the profile on post #9 to accompany this.
The set tasker icon basically puts a lock icon on the notification bar. This is so that I know if the DnD is turned on or off. ;)
and... to make things more easier... I've included the profile and task xmls.
Dropbox...
Task - DnD (you may have to rename to DND.tsk.xml)
Profile - Block Calls (you may have to rename to Block_Calls.prf.xml)
