Help Do not disturb
jamos316
Hi can you help me with setting my do not disturb access. I have Android marshmallow so it's the default function inside sound & notification settings.
I have only 1 setting and that's to come on every night at 11 and shut off at 9:30 every morning,it is set to allow priority only which I have set to allow starred contacts only plus I think it still let's the alarm sound.
At the time I set it up it seems to work but not the days after. I don't know why?
I have Tasker app and I have seen one article that this is what interferes with it but it did not give a solution. If that's the case that tasker is interfering then can I just setup a trigger in tasker to do the same action?
