mystvearn
Since I donated my desk alarm clock, I now rely solely on my SGS2 to wake me up in the morning. I have alarm clock plus app which is great. It has a dock clock that goes from bright white to dim green (default colours). I use both the clock that comes with the phone and alarm clock plus-just in case one of the apps freezes.
The only problem with alarm clock plus is that while the clock and dim feature work well, the clock is not that big. I have resorted to using dock clock (free version). The app is ok, but it is slightly slow at showing the clock. I have it to auto turn to clock mode whenever I charge the phone which is every night. My phone's screen timeout first (30 secs) before the app can launch properly resulting I have to manually unlock the phone just so that the app will be seen.
Is there a better clock than this? I have seen my friend's Lumia 920 with NFC Tags and NFC Launchit. The clock there is slick. Nothing I have found on the android app.
Problem with using:
stock touchwiz dock: the clock is blue, and too bright. Makes no sense when I want to sleep at night.
Alarm clock plus does most of the things I require it to but clock kind of small.
Desk clock: works well but slow to load after placing the phone charger and the weather app requires you to manually type in the location! The paid version has auto location.
I can cure the sluggishness of the app loading time by:
1. Using tasker to make a specifc task-app launcher when the app is connected.
2. Using the auto launch function in alarm clock pro to launch the app after I've connected it.
Does anyone know where to find the desk clock (paid version) review/walkthrough. The google app market tells you features, but does not show enough screenshots and I can't find a youtube video showing me the clock.
Also, is it worth it to get the paid version over the standard version? Is this the best android dock clock replacing my bedside alarm clock?
Problem with using:
The settings I shared are from Alarm Clock Plus. There's tons of settings in there to do what it is you're wanting to do. You can make the font size really huge on the screensaver. I think you're just missing (not finding) where all of the settings are located for it.
