Dock for Skyrocket?
camper66
Is there a dock that works with the Skyrocket? I know there is one for the original Galaxy S2, but I don't think it will fit the Skyrocket. How about the dock for the T-Mobile version since it is close to the same size? Thanks.
Desktop dock or car dock?
The Infuse Samsung car dock works. The Skyrocket is a bit loose in the dock, but once you connect the USB it's not going anywhere. I've driven about 50 miles so far and it's never even thought about falling out.
The dock was $17 at ATT.com last week.
you can look at the Sinjimoru Sync and Charge Dock Stand.
  • sinjimoru-sync-and-charge-dock-stand-for-samsung-galaxy-s2-sii-i9100-color-option-black-micro-us.jpg
does it send audio to the radio from the mount instead of having to plug the 3.5 plug into the top of the phone?
my car mount from mt sgh-i777 wouldn't do it even though it said it was in
driving mode
thanks,bigcid10
The Tmobile T-989 dock should work. I can't post links yet but the Samsung part number is:
ET-CGPK004GSTA
Not if you're planning on using the internal speakers, it won't.
driving mode
thanks,bigcid10
It sends audio to the car stereo via bluetooth.
If you're not using bluetooth then you'll need to use the 3.5mm plug.
I bought the Infuse Vehicle Dock and the Infuse Desk Dock. Both work perfectly with the Skyrocket. I've just ordered the RND dock and the Sinjimoru Sync and Charge Dock Stand and will update once I try them out.
I have to say I have to agree that there's surprisingly little OEM for the Skyrocket. It's a great phone and one of the best from AT&T.
