Dock not recognised
Oblig
Member
So I sent my Prime back (without dock) and they have fixed the camera, white spot on screen and changed the wifi module.
Now it won;t recognise the dock :mad:
That is very strange. When I sent my Prime back for a camera fault I sent it in without the dock and it worked fine afterwards. :/ Does the unit charge up ok and work ok if you plug it into your PC?
Unit works perfectly - GPS attachment and connecting to PC flawless.
The keyboard is the issue just doesn't seem to recognise it, a couple of times I have wiggled it around and it says the keyboard is there but with no charge and I can't use it, yet the keyboard seems to take a charge on its own - very annoying.
Battery is dead on mine, so I can't confirm, but I believe the first time you dock it you must choose to use that keyboard vs on screen?
What happens when you open up a text box? Does the on screen KB pop up while you're docked? Does it give you the option to change text input?
It has been returned all now working perfectly - the label says 'no fault found' weird indeed. They have not suggested a charge either
