Yes.Will a hard reset delete all of my games and apps?
Yes. But of course you save everything on the card.If I pull the SD card before the reset will it still do it?
No. Everything on the phone is erased. You'll need to reinstall all your apps.I know with alot of games when you move them to the SD card there's still a mb or two on the phone, will that come back after replugging in the card? Thanks
Even if the apps are on my SD card?Yes.
Yes. Some system files are installed on the phome.Even if the apps are on my SD card?
No.Also, will I have to pay for them again or no?
Also how do I access the factory reset again lol...and how to pull my sd card?...
Is there a setting that lets me delete stuff off my SD card? Or APP?
I just want to be able to keep files...so I think I'll wait till I get my phone to USB cable here and I'll save all my pictures on it and i can delete my games, is it possible to download apps onto my PC and then move them to my phone vis USB? As my data plan is $30 for 300mb...
