Does Android Device Manager work with Droid X?
wrench
Using the Android Device Manager from a computer, I can ring my Droid X and can also lock it with a new password, but cannot locate it. I just get "Location unavailable". ADM works fine with my Galaxy Tab.
Anybody have their Droid X working fine with ADM?
You're on a custom ROM as at least Gingerbread? Are any other apps using GPS affected?
Yes, a custom ROM: CyanogenMod 7.1
Android 2.3.7 (Gingerbread)
GPS seems to work, though it does take a long time, e.g., when using Google Maps.
Is that how ADM does the locate? It uses GPS even when GPS is turned off on the device?
