Help Does anyone eles's galexy..
One says find sexy singles in your city, #local dateing app. another says scan for viruses with android armour scanner. Has been sending me these since day one.
Sounds like an app you have installed is pushing ads to your phone. I would go through the apps you recently installed and remove them to see if that resolves the issue. There are also several apps on the Play store that will scan your phone and tell you which apps it might be.
The next one you receive, just press and hold on the drop down notification panel and your phone will tell you which apps are generating them.
