Help Does anyone else lose data connection randomly?
jkoch2272
I lose my data connection a few times a day. I'm on Verizon. It only lasts about a minute but it's really annoying. Does this happen to anyone else?
It's nothing but a network problem, especially if you are moving around while using the phone. Where is it worst? Check your network provider's network map and you'll see that the problem is worse wherever their signal is weak. I use Sprint, and the BestBuyMobile personnel have acknowledged that this is most always the problem.
False, not a network problem, mine only does it when lte4g is enabled. But will do it while I'm sitting right next to my air rave with crazy signal strength. The lte on this phone is not ready for prime time. Hope this is not a hardware issue.
I mainly notice it at work because that's when I'm using it most. I work in downtown Cincinnati so there shouldn't be any kind of problem with a weak signal. It just seems to stop working then it will randomly come back...
I lose it sometimes also, but mostly it's 4g I seem to loose. I correct it by cycling airplane mode. I do think there is a software issue with the phone.
If you're in a concrete jungle, your signal will be blocked/deflected/echoed by tall buildings.
:fight:Good day everyone. I just recently purchased a New Galaxy S3 from a local Spint store. I have been a loyal Sprint customer for 15 years. I have owned many different phones (Star-Tac, Sony, Touch-pro 1-2, Evo, EVO 4G) Over the past 2 weeks since buying the S3, I've noticed a SERIOUS drop in network connectivity, both Data & Cell for absolutely no reason. Now, stop me if I'm wrong, but on my Evo 4G, I could connect to the internet EVEN if I didn't have a 3g signal... As long as I had Cell bars, I could access the web no problem. So the S3 is giving me some headaches and I've seen on other forums that others are too. These people are on diffferent carriers too.
So here's my issue. When I'm in a GOOD STRONG Sprint network, I've been attempting to access the web (Google Store or You-Tube) and have seen the 3g or 4G icon on the bar show data up/downloading then WINK, they dissappear and I get a "No connection RETRY" window. I've made many changes, selected CDMA instead of CDMA/LTE, vice-cersa. I've updated PRL, Profile, Firmware and even have the new Jelly Bean 4.1.1
I've contacted Samsung and "Chatted" with a technician, but this person had NO clue of this issue... I gave them the links to this and other Android forums...
So do I take it back? Revert back to my Evo? I have to say, the speed and versatility on the S3 when it's good, is GREAT, but I'm not one to have some half good, especially one so expensive...
Any imput is appreciated...:D
