Help Does anyone know...
thedrizl
How to keep the phone from resetting to Global mode whenever you reboot? It seems like the GSM radios are draining the battery even more than LTE.
Iv'e had this issue once. Since then I have selected LTE/CDMA in mobile networks. It has not gone back to global yet. Does it go to global everytime you reset?
Yes, it does. It's a minor inconvenience, but still annoying.
For some reason sometimes the most minor inconveniences can be the most annoying. ;)
Anyways, that's strange that it is persistent every time you reboot. Have you tried clearing cache or doing a factory restore?
I did a FDR about a week ago, and rebooted the phone about 2 days ago. It switched back to global after reboot. It may just be my phone, or the fact that my signal is spotty at home. I'll have to try it at work one day.
