No "case" per se. If you looked around the accessories thread, you might have found a reference to a thing called the PowerSkin. Battery/case combination, kind of.
I have the powerskin for my phone and, so far, I like it. It keeps my phone battery at 100% for at least 12 hrs with moderate use. It does add some weight to the phone, but I like the extra weight and thickness, easier to hold onto. The silicone rubber feels nice in the hand and it makes the phone non-slip. I have only a couple of negatives about it, one being the usb connection doesn't pass through, you have to remove the case to get the phone to connect using the usb cable. I wish the rubber fit a little better. Charging time is about 4 hrs. I had the Otterbox Defender for a while but hated the plastic screen cover, it distorted the screen image when the plastic got a little skin oil on it. Overall I like the powerskin case.
