Does anyone use TeleNav? Wont ever launch...
heyjoojoo
TeleNav wont ever launch, it gives me this message that it needs to install an update. So when I click Update Now, it just launches the Play Store. So, when I click on 'open' while Play STore is open, it brings me back to the 'Update Now' dialogue.
Not sure how to get this to run.
I had problems when I first started using it too. I don't recall how I resolved it, but a quick Google search turned up a suggestion: uninstall and reinstall.
I have been using TeleNav for a while now, and I like it. I sometimes have a quirk where if I type the address directly into TeleNav, it won't find a GPS signal. Then, I back out, type the address in Google Maps, click Navigate and select TeleNav, it works fine. YMMV
No issues with Telenav for me at all. And it's all I use for my nav purposes. I too would say uninstall and reinstall. That's what I would do.
