What does Data Enabler do? Will it effect my battery poorly?
So, if I am home and my WiFi is on, my data is off and not using my battery?
You don't, forget about another app to have running.So, if i have a widget to turn off my WiFi, my data turns back on when my WiFi is turned off, right? Why would I have a need for a Data Enabler if I am enabling my data upon turning off my WiFi?
So, lemme get this straight
No custom anything, no ROM.
I'm confused because, while in Wi-Fi mode, my data connection still says that it is on (in my settings).
So, it may not be using the data connection, but is my phone still looking for a data connection? Is that draining my battery?
