Could you provide any details as to why you need a phone that's indeed impervious to chemical contact too? This sounds like you need to be looking into a specific, highly insulated mobile device, not just some typical consumer phone.
The IP standard for smartphones is something that focuses on very common problems, exposure to water and/or dirt. Exposure to something like gaseous compounds just isn't something people usually have to worry about.
What sort of gaseous chemicals, like explosive, flammable, corrosive, toxic, etc?
I know if some places are dealing with explosive and/or flammable gases, you must only use devices that are approved as Intrinsically Safe(IS). https://www.safeopedia.com/definition/79/intrinsically-safe-is#:~:text=Intrinsically Safe is a technique that is adopted,energy (thermal or electrical) available for the system.
this is an english only site:当然不是指很高浓度的化学气体了,同志。
高浓度连人都会死。
Of course it doesn't mean very high concentrations of chemical gases, comrade.
Even people will die at high concentrations.
i have worked at restaurants in the kitchen as a line cook with my phone.....never had any issues. i would not worry about it too much unless you work with crazy gasses like in a lab or something of that nature.Working in construction sites or renovation, you are likely exposed to chemicals in gaseous form you can imagine
Even working in a kitchen, you are exposed to cooking gas or odor from different foods.
