any sites/tutorials you suggest on doing this?I haven't used it personally, but others have. You'll need to patch the SD card permissions first.
Works great. I did a dual partition for mine. 16gb class 10 u1 good speed. Half ext 4 and other half fat 32. One half for the aids the other for storage. I have close to 200 apps and still running smooth.I'm quickly running out of room for apps. Does link2sd work for our device?
It's not saying the device is not supported. It's saying the because this device uses emulated storage, you have to partition up your SD card so that there is an ext4 partition on it to move apps to. It will not do it for you, which is why halrulez suggested aparted.I used the SDfix app to set premissions https://play.google.com/store/apps/details?id=nextapp.sdfix&hl=en and then tried to used link2sd pro to move over a game to my SD and it says my device is not supported. Didn't see any where to make a new partition or anything. Can I not move games over or is there a limited type of apps I can switch to SD?
Do you have the instructions for this?
Thanks!!
