Dolphin Bookmarks -please help
Teris
HI all. I'm having a terrible time trying to get my bookmarks from Dolphin on my S3 to my new Nexus 7. Does anyone know to transfer them? I can't possibly go and input them all manually without going insane. Thanks for any help you can provide!
This is a weird way to go about it, but if both devices are rooted I belive you could back up dolphin with titanium, and then restore the backup onto the nexus 7. Not sure if that would even be faster than just manually entering them, but if you have a lot then I guess it might be.
Teris
2-*EASY* *EASY* Solutions,
I'll give you the *COOL* one first (then the standard standby).
*EDIT*(POST INITIAL POST)
USING "DOLPHIN CONNECT"
Provides Ability to Throw Back/Forth Phone to PC/PC to Phone
Extension Locations:
FF URL: https://addons.mozilla.org/en-us/firefox/addon/dolphinconnect/
Chrome URL : https://chrome.google.com/webstore/detail/dolphin-connect/pajecklcmiegagoelbbjldmfcbcpdpll?hl=en-US
Web Management
https://sen.dolphin-browser.com/manage
NOTE: You'll need an account to see what I see
---*SAVE THIS URL* (as it's not intuitive/"easy" to get to/remember)
What the ad on/extension does
--of course sync's everything
--Bookmarks
--Passwords
--Open Tabs
--History
---Provides ability to Throw open page *FROM CPU TO DEVICE*/from *DEVICE TO CPU*
-------*NOTE*---
Some reason *today* (10-12-2013)--it's having hiccups. Crashed on me twice. (*FROM DEVICE TO CPU*). I don't think this is resident to my phone as I'm logged into the cloud (Successful) and can throw from CPU to Phone (successful)
*THUS*--if you try today. (Phone to CPU) Be patient with it (must be something on their end).
IS IT STILL SYNC'ing (and needs "Cloud" both ways..so *shrug* (??)
---PROVIDING HELP LINK (ANDROID TO PC)--The new Dolphin Rev. not 100% Intuitive.
FROM ANDROID DEVICE to PC
http://www.dolphin-browser.com/help/extension.html
Have to go to MENU/Accounts and Service /Dolphin Connect Account and Create a *DOLPHIN CONNECT ACCOUNT*. (AFTER INSTALLING EXTENSIONS)
******(NOT INTUITIVE)-this use to be on the bottom rail--is not in new version)
--Click the "Menu" button
New version:
----to get to the "Menu" on the new Version--you now have a greyed out circle with a Dolphin inside it. (either bottom left/right. You choose where to place it)
You have to *PRESS AND HOLD* (EX-not a sticky).
Doing this will Pop open 3-Cirles.
DRAG the Dolphin to the one that looks like a Page with (4) four lines on it.
--Click "Settings"
--Click "Accounts and Services"
---*CREATE "Dolphin Connect Account" (first choice) On your Device.
*MUST*--TO USE EXTENSIONS ABOVE. (throw BACK/FORTH---sync back/FORTH/ETC.)
Be sure to remember what you use for Loin to "Dolphin Connect Account"
Dolphin/Phone you'll need the same for CPU Extension/ADD ON USE
USING DOLPHIN CONNECT
DOLPHIN HELP "Extensions Help:
*VERY SIMPLE* (Printing to show how Easy)
---Makes sure logged into Dolphin Connect/Cloud (swipe to right click cloud at top of bookmarks)
--Click Grey Dolphin /Drag to (4) Line Menu
--Click "Share Page" (note if you don't see this option/greyed out--you're not logged in)
--Select "Send to Device" (your PC NAME/PC Icon)
That's it (VERY VERY Simple)
Ping again if you need help I'll help you.
Congrats on the wise choice of using the best browser in the world that thing is blazing fast
=-O
R.
PS--2ND-WAY---THE GOOD OLD FASHIONED WAY.
Old fashion standby Create Dolphin account and back up to cloud (EXACT SAME as above, only missing the "Extension" on CPU
If you're on new version settings bit more hidden (again, same Instructions as above)
Greyed out circle-Dolphin inside it.
-Press AND HOLD (ex=not a sticky)
Up will pop three icons...Drag to the one 4 lines on the short cut.
--Up pops settings.
--Click Settings
--Scroll down to Accounts & Services Choose which way/where to sync to.
Places your decision.
-FYI. FB--If you login with FB, the sync is NOT TO FB, just your login credentials (still syncs to cloud)
-Twitter
-Evernote
-Box
I used this method before the Chrome/FF way (always reliable)--ie. Uninstall/Reinstall Dolphin (just reconnect, Cloud Sync ::Poof:: all good!
If you need any help/questions. Let me know!
R.
Thanks, Daniel, but I'm not rooted.
2012HereForNow - thanks. I'll give this a try. I tried Dolphin Connect and it just would not work. Thanks very much for your help. I'll let you know if it works!
