Dolphin Jetpack!
I downloaded dolphin and jetpack yesterday. It is way better than Chrome, which I was using. I love the sonar and gesture feature too.
The only thing I miss about chrome is incognito tabs. Does Dolphin have a similar feature. Let's just say that my spouse does not approve of some of my cinematic choices online.
Been using Dolphin for a couple of months. Loving it. The new version 9 plus JetPack is outstanding. Has been working flawlessly for the last couple of days.
I'm a long time dolphin user and jetpack seems nice, but when I have jetpack on, I can't bring up the tab bar by tapping on the screen. Without jetpack, I can tap on the screen (and slightly scroll) and the tab bar appears. With jetpack running, I either have to hit menu or scroll all the way to the top of the page to make the tab bar appear. That's a deal breaker for me.
a
Check if you have fullscreen enabled. If so, try disabling it.
I had the same problem, and this solved it.
a
Where is that option? I can't find it.
It works fine without jetpack though, so if it's the fullscreen option, wouldn't that make it not work for both?
You can always just close the tab and then hit the back button twice. It will give so some options before it closes and you can delete all history each time you use the browser. Set it to "Always" delete the history and you're good to go.
