You will want to check inside the forum for your specific device model. Select it from the list here and join your device's area of support - where you'll find the other users of the same device love to hang out... and will be the best place to get device specific help.
If you should need further assistance, feel free to ask. ↖(^▽^)↗
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
